Type C Rolling Friction
here Mr is the total damping torque vector, Mrk is the non-viscous damping torque vector and Mrd is the viscous damping torque vector. The non-viscous damping torque vector is a function of the relative particle rotation angle and the rolling stiffness as defined in Equations 2 and 3.
(2) | |
(3) | |
(4) |
where k r is the rolling stiffness, θ r is the relative rotation angle, R r is the equivalent rolling radius, k n is the normal contact stiffness and μ r is the coefficient of rolling friction.
The viscous damping torque vector is defined in Equation 5 and is function of the relative rotational velocity vector at the contact point and the rolling viscous damping ratio.
(5) |
where η is the rolling viscous damping ratio, I r is the equivalent moment of inertia for the rotational vibration mode about the contact point and ω is the relative rotational velocity vector at the contact point.
In cases where significant non-viscous rolling resistance is expected at particle contacts such as when contact forces are high or the modeled material consists of predominantly angular particles, the use of Type C rolling friction may result in a more physically accurate behavior and greater stability of the EDEM model.
