Importing CADFEKO Model Files (.CFX)
Import an existing CADFEKO model (.cfx file) into a CADFEKO model.
On the Home
tab, in the File group, click the
Import icon. From the drop-down list select the
CADFEKO Model (*.cfx) icon.
- Select the .cfx file you want to import.
Under Import, select the entities to import (for
example, geometry, meshes, meshing rules, cable definitions, solution entities
and optimisation searches).
Figure 1. The Import CADFEKO Model dialog.Note: Frequency, infinite planes and mesh settings are not considered during the import process and will not affect the destination model in any way. -
[Optional] Merge identical variables and media in the imported model and target
model.
- To merge identical variables and points, under Merge options, select the Merge identical variables and points check box.
- To merge identical media, under Merge options, select the Merge identical media check box.
- To merge identical media, under Merge options, select the Merge identical workplanes check box.
- [Optional] If there are naming conflicts between the names of the imported entities and the existing entities in the model, in the Prefix field, enter a prefix that will be pre-pended to all imported entity names.
- Click OK to import the file and to close the dialog.
