Parametric distribution with Flux
This document guides you through using parametric distribution with Flux.
Introduction
This chapter discusses the establishment of a parametric distribution in Flux. The
        distributed computing allows the user to save computation time while distributing several
        independent configurations of a same Flux project. For example a Magnetic Transient project
        may be distributed regarding differents values of parameters such as the geometrical
        parameters (size, shape etc...) or physical parameters (supply current values, speed...)
        varying in the scenario. Several projects will run at the same time simulating all those
        configurations, the main parameter of a distributed computation is the following:
    - The number of running Flux in parallel;
