Aerodynamics and Aeroacoustics supports the P-FSI approach available in
        AcuSolve (based on the eigenmodes of the structure). Each part can be defined as flexible
        and the corresponding op2-file (containing the eigenmodes of the structure) can be assigned
        to each part individually. OptiStruct can be used to compute the
        eigenmodes up front.
            The eigenmodes computed in OptiStruct are based on the
                location and orientation of the structural model. If the location of the model in
                    Aerodynamics and Aeroacoustics is not the same as the one used to
                compute the eigenmodes, the P-FSI job does not work correctly.
        Certain functions are not supported yet via the Aerodynamics and Aeroacoustics workspace. If any changes in the .vpar file were required, the Aerodynamics and Aeroacoustics job has to be submitted manually via the command
            line. The .vpar file can be generated
            by clicking Export in the Run
            dialog.
                Change the number of used modes (use less modes than present) by entering the
                    following line to the .vpar
                    file: flex_comp_1_modes = 6
                The number of modes considered for the simulation is set by default to the
                    number of present modes in the eigenmode file. This will cause the usage of the first six eigenmodes of the eigenmode
                    file corresponding to flexible component 1. If the number of modes is set to a
                    higher value than the present modes in the op2 file, then the maximum number of
                    modes is chosen. The pressure loads onto the parts are ramped over several time
                    steps, to avoid a “shock” of the pressure loads onto the structure. Per default
                    the ramping is linear between the time steps eight and 16 from zero to the full
                    value. This yields the following default entries in the  .vpar
                    file: mult_lower 	= 8		// loads have no effect on the structure till here
mult_upper	= 16		// loads have full effect on the structure from here
                Change the default time step interval for ramping in case it is to large or if
                    it starts too late by editing the .vpar file (the .vpar file can be generated by clicking
                        Export in the Run dialog).
                Monitor results, for example displacement of the structure over time, by
                    defining monitor points.
                For each monitor point, add the following lines to the  .vpar
                        file: time_history_1_name 	= “point name”	  // the name of monitor point
time_history_1_coord	= ( 3.1, 0.0, 0.223 )	  // the (x,y,z) coordinates
time_history_1_output	= ( “x_displacement” )	  // output type for the report
 Define
                        a second or third monitor point by replacing the one in the above commands
                        by two or three. Multiple outputs can be chosen, separated by comma. The
                        possible candidates are x_displacement, y_displacement, z_displacement,
                        displacement, x_velocity, y_velocity, z_velocity, velocity, and pressure.
                        The displacement options refer to the mesh displacement at the given
                        coordinate point.
                Create animations by editing the .vpar file:
                    animation		= True	      // activate animation
saved_sates	= 50	     // keep the last 50 output files
outputFrequency	= 2	     // write output at every 2nd iteration
 Activating the animation mode will generate one animation of a cross
                    section through the entire body with the velocity magnitude as contour plot.
                    Additionally, for each flexible part, three separate animations will be
                    generated: one animation for the displacement (surface contour plot), one for
                    the pressure (surface contour plot) and one animation showing a cross section
                    cut with the velocity magnitude.
