PARAM, CHKM0
Bulk Data Entry OptiStruct calculates the ratio of m0/mlog0 and prints a WARNING if the frequency interval may not be fine enough for accurate Fatigue Damage calculation.
Parameter | Values | Description |
CHKM0 | <YES, NO> |
Where,
- If m0/mlog0<0.95 , a WARNING message is issued indicating that the frequency interval does not seem fine enough for calculation of accurate moments. This implies that the frequency interval may not be fine enough for accurate Fatigue Damage calculation. A way to improve this is to increase number of frequencies defined on the FREQi entries appropriately.
- If the frequency interval is fine enough, you can expect m0 and mlog0 to be close to each other. If mlog0 is greater than or equal to 95% of m0 , the m0 value can become stable with regard to number of frequencies. If the m0 value is stable, the subsequent Fatigue Damage values are also stable.
