Export Solver File Options
- File Name
- Solver file export name.
- Include File(s)
- Select exporting of include files.
- Pre Output CSV
- CSV file containing the E-Lines definition.
View new features for Altair HyperWorks 2023.1.
Technology and problem evaluation approaches used in SnRD.
Explore the SnRD Pre-Processing user interface.
Use the tools in the Setup Group to setup evaluation lines and define loadcases.
Evaluate loadcase and export solver deck.
Use the Review Loadcases tool to review loadcases present in the model and choose which loadcases to export in the OptiStruct solver file.
Use the Export tool to export loadcases and variability studies.
If a variability study is created in the session, an additional export option is available to allow for export of a variability study session which can be opened in HyperStudy to run a Stochastics or a DOE study.
Assess the squeak and rattle risks by viewing the results from the squeak and rattle analyses.
Create a summary report for the risk assessment of the squeak and rattle analysis.
Launch and explore SnRD Post Processing.
Use of Altair Ziegler SnRD Material Database.
Figure 1. © 2023 Altair Engineering, Inc. All Rights Reserved.
