Move Patches and Merge Boundary Nodes
Use the Stitching tool to attach the various patches by moving patches and merging boundary nodes.
Each patch should have materials, properties and contacts assigned.
View new features for Altair HyperWorks 2023.1.
Use the Read Positions tool to read .h3d node positions.
Use the Create Table tool to create a table on which the airbag will be folded.
Use the Flatten tool to flatten the airbag.
Use the Housing tool to fit the airbag to housing/container.
Use the Presimulation tool to convert the airbag to Radioss format and prepare it for the next folding steps.
