Numeric Calculations
Numeric calculations allow new numeric columns to be created.
They typically use one or more of the following operators:
    Operator  |
    Name  |
    Description  |
    Logical NOT  |
    Logical NOT.  |
    Integer Division  |
    Integer Division  |
    Logical AND  |
    Logical AND.  |
    Multiply  |
    Multiplies two numbers.  |
    Add  |
    Adds two numbers.  |
    Subtract  |
    Subtracts two numbers.  |
    Divide  |
    Divides two numbers.  |
    Less than or equals  |
    Less than or equals to.  |
    Not Equals  |
    Not Equals.  |
    Equals  |
    Equals.  |
    Greater than or equals  |
    Greater than or equals to.  |
    Raises to the power  |
    Raises number to the power of number2, number1 ^ number2.  |
    Logical OR  |
    Logical OR  |
And one or more of the following functions:
    Function  |
    Description  |
    ABS  |
    Absolute value, which can be used as ABS(X).  |
    ATAN  |
    ArcTangent function which can be used as ATAN(X).  |
    CEIL  |
    Ceiling function. Examples: CEIL(-3.2) = -3, CEIL(3.2) = 4.  |
    COS  |
    Cosine function which can be used as COS(X), where X is a real-type expression. COS returns the cosine of the angle X in radians.  |
    COSH  |
    Cosine Hyperbolic function which can be used as COSH(X).  |
    COTAN  |
    Cotangent function which can be used as COTAN(X).  |
    EXP  |
    Exponential function which can be used as EXP(X).  |
    FLOOR  |
    Floor function. Examples: FLOOR(-3.2) = -4, FLOOR(3.2) = 3.  |
    HEX2DEC  |
    Converts a hexadecimal number to decimal. Example: HEX2DEC("FF") = 255  |
    IF  |
    Conditional Statement The IF(b, case1, case2) function provides branching capability. · If b is True, then it returns case 1. · If b is False, then it returns case 2. · If b is a numeric value 1, it is equal to True. · If b is a numeric value 0, it is equal to False. NOTE: By default, the function returns a value of data type Text. To force the data type to numeric, you can either use “Set type manually” or do a calculation with a numeric value, such as multiply by 1. Examples: IF([Actual] >= [Budget], “Good job”, “Not done”) IF([Some_Number] = 0, 0, 1/[Some_Number])*1  |
    INTPOW  |
    Raises Base to an integral power. Example: INTPOW(2, 3) = 8. Note that the result of INTPOW(2,3.4) = 8 as well.  |
    ISNULL  |
    If the measure Is Null or NaN, then 1 is returned, else 0 is returned.  |
    LN  |
    Natural Log which can be used as LN(X).  |
    LOG  |
    10 Based Log which can be used as LOG(X).  |
    LOGN  |
    The LogN function returns the log base N of X. Example: LOGN(10, 100) = 2  |
    MAX  |
    Maximum of two input values. Example: MAX(2, 3) = 3  |
    MIN  |
    Minimum of two input values. Example: MIN(2, 3) = 2  |
    MOD  |
    Remainder of division. Example: MOD(7, 3) = 1  |
    POW  |
    Raises Base to any power. For fractional exponents or exponents greater than MaxInt, Base must be greater than 0.  |
    RANDOM  |
    RND(X) generates a random INTEGER number such that 0 <= Result < int(X). If X is negative, then result is int(X) < Result <= 0. RANDOM(X) generates a random floating point number such that 0 <= Result < X. If X is negative, then result is X < Result <= 0.  |
    REGEX_EXTRACT  |
    Returns matching data from the value based on regex. Expression is REGEX_EXTRACT("value", "regex")  |
    REGEX_EXTRACT_GROUP  |
    Like the REGEX_EXTRACT function, apart from the third “group” parameter, which defines which group, as defined by the regex expression, to return. Group is a string parameter and can contain either an integer value or a group name. Examples: · REGEX_EXTRACT_GROUP(“some123”, “([a-z]*)(\d*)”, “1”) = “some” · REGEX_EXTRACT_GROUP(“some123”, “([a-z]*)(\d*)”, “2”) = “123”  |
    SIGN  |
    SIGN(X) returns -1 if X<0; +1 if X>0, 0 if X=0; it can be used as SQR(X).  |
    SIN  |
    Sinus function which can be used as SIN(X), X is real-type expression. SIN returns the sine of the angle X in radians.  |
    SINH  |
    Sine Hyperbolic function which can be used as SINH(X).  |
    SQR  |
    Square function which can be used as SQR(X).  |
    SQRT  |
    Square Root function which can be used as SQRT(X).  |
    TAN  |
    Tangent function which can be used as TAN(X).  |
    TRUNC  |
    Discards the fractional part of a number. Examples: TRUNC(-3.2) = -3 and TRUNC(3.2) = 3  |
