Modifying User-Defined Columns
A generated column can be modified.
1. Modifying user-defined columns can be done either by clicking:
·         the Edit
 button
	 of a generated column title in the Data Preview
· the Calculated Columns button on the Data Sources Settings pane and clicking the generated column to be modified.
The corresponding user-defined settings is displayed.
2.     Modify the properties or settings and
	 click
  to
	 save the changes.
