Automatic Parameterization
Determines whether parameters are to be automatically updated or the setting will be inherited from the workbook property.
q On
When
	 turned on, parameters can be automatically updated within a dashboard
	 by right-clicking on a visualization item and selecting it from the
	 context menu with the lightning
 icon.
The dashboard parameter values to be passed will include all possible data table values of the selected visualization.
For example, if there are Region and Industry dashboard parameters, and the associated data table of the visualization has a Region but no Industry column, then the Automatic Parameterization option will only include:
However, if the associated data table of the visualization has Region and Industry columns, then the Automatic Parameterization option will include both:
q Off
Automatic parameterization on the visualization based on the dashboard parameters is turned off.
In some circumstances, it may be appropriate to disable this automatic parameterization, and instead utilize more configurable navigation actions.
q Inherit
The automatic parameterization is inherited from the workbook property.
