Sync
Synchronization determines whether the visualization should interact with other elements on the same dashboard:
    Property  |
    Description  |
    Row Filtering  |
    Tap the slider to turn it on. This causes the visualization to use the categorical and numeric filters on the dashboard.  |
    Time Filtering  |
    Tap the slider to turn it on. This causes the visualization to use any time filters on the dashboard.  |
    Selection  |
    Tap the slider to turn it on. This means, the items selected in another visualization will also be selected on this visualization.  |
    Focus  |
    Tap the slider to turn it on. This means, when focus is set on another visualization the system will also set focus on this visualization.  |
You can also enable the Synchronized Variables of the visualization’s variables.
