Moving a Data Table to Data Library
A data table that was created in the Workbook Internal Data Table Editor can be moved to the Data Library.
1.     Click
	 the Move to Data Library
 icon
	 of a data table in the Data Tables list.
The Publish Data Table dialog displays.
2. You can opt to enter a new Name of the published data table.
3. Select the folder or subfolder where the data table will be published .
4.     Click
The moved notification message displays.
    NOTE  |
    · The data table is removed from the Data Tables pane in the Workbook Internal Data Table Editor. · The original data table is removed from the workbook and replaced with a linked data table, pointing to the data library.  |
