Cross Tab Axes
Visualizations that support cross tabbing, include the following settings for both the X and Y axes.
    Setting  |
    Description  |
    Leaf Bar Thickness  |
    The thickness of the leaf or lowest level of data. The default value is 80.  |
    Leaf Label Angle  |
    The Label angle of the leaf or lowest level of data of the crosstab axis. Default is 0, accepts values between -90 and +90.  |
    Inner Bar Thickness  |
    The width or height allocated for the non-leaf components of the crosstab axis in pixels. Default is 80.  |
    Inner Label Angle  |
    The angle of the non-leaf labels. Default is 0, accepts values between -90 and +90.  |
    Min Interval Length  |
    The minimal interval in pixels between cross tabbed visualizations. Default is 100.  |
    Max Interval Length  |
    The maximum interval in pixels between cross tabbed visualizations. Default is 400.  |
    Word Wrap  |
    Determines whether to wrap the crosstab axis text.  |
