Table Visualization Axis
The Y axis of the Table visualization includes the following settings:
    Setting  |
    Description  |
    Leaf Bar Thickness  |
    The thickness of the leaf or lowest level of data. Default is 80.  |
    Leaf Label Angle  |
    The Label angle of the leaf or lowest level of data of the crosstab axis. Default is 0, accepts values between -90 and +90.  |
    Inner Bar Thickness  |
    The width or height allocated for the non-leaf components of the Table axis in pixels. Default is 80.  |
    Inner Label Angle  |
    The angle of the non-leaf labels. Default is 0, accepts values between -90 and +90.  |
    Row Height  |
    Defines the height of table rows in pixels. For tables created in versions before 2021.1 the configured “Minimum Interval Length” is used. Default is 30.  |
    Word Wrap  |
    Determines whether to wrap the visualization axis text.  |
    Show All Column Levels  |
    Determines whether the space in the text axis should be allocated to all hierarchy levels, whether visible or not.  |
    Show Column Labels  |
    Determines whether column labels are visible or not. Enabled by default.  |
    Show Grid Lines  |
    Determines whether grid lines are visible or not.  |
    Show Zebra Stripes  |
    Determines whether to display alternating row colors (like zebra stripes) in the table.  |
    Foreground  |
    Foreground color of the Y-axis.  |
    Background  |
    Background color of the Y-axis.  |
