Latitude & Longitude Variables Configuration
The Longitude and Latitude variables are available in the Map Plot visualization. These coordinates are used to locate a place on Earth’s surface.
The configuration pane for Lat and Long Variables is the same as for the Size variable.
    NOTE  |
    Default aggregation for the Latitude and Longitude variables are: · Mean for numeric columns. · Calculation for calculated columns. · External if data table contains external aggregates for the column.  |
