Abs
The sum of absolute values of the selection.
This method returns the sum of the absolute values of each item in a set of numbers.
The absolute value of a number refers to the number without its sign.
Adding each item of a set of numbers will produce its total or sum.
Sample 1
Given a list of arbitrary numbers:
        Arbitrary  |
        3  |
        2  |
        1  |
        0  |
        -1  |
        -2  |
        -3  |
        0  |
        0  |
        0  |
A list of positive and negative numbers
1. Compute for the absolute value of each item.
        Arbitrary  |
        3  |
        2  |
        1  |
        0  |
        1  |
        2  |
        3  |
        0  |
        0  |
        0  |
The list of absolute values.
2. Compute the sum of the absolute numbers.
3 + 2 + 1 + 0 + 1 + 2 + 3 + 0 + 0 + 0 = 12
Sample 2
Assuming that the same list of numbers has multiple groupings or breakdowns as shown below.
        Grouping  |
        Arbitrary  |
        1  |
        3  |
        1  |
        2  |
        1  |
        1  |
        1  |
        0  |
        2  |
        -1  |
        2  |
        -2  |
        2  |
        -3  |
        3  |
        0  |
        3  |
        0  |
        3  |
        0  |
The list of values with groupings.
1. Compute for the absolute values of each item based on the Grouping defined.
        Grouping  |
        Arbitrary  |
        1  |
        3  |
        1  |
        2  |
        1  |
        1  |
        1  |
        0  |
        2  |
        1  |
        2  |
        2  |
        2  |
        3  |
        3  |
        0  |
        3  |
        0  |
        3  |
        0  |
The list of absolute values with groupings.
2. Compute the sum of the absolute numbers based on the grouping.
        Grouping  |
        Arbitrary  |
        1  |
        6  |
        2  |
        6  |
        3  |
        0  |
The final result.
Computation Details:
Group 1: 3 + 2 + 1 + 0 = 6
Group 2: 1 + 2 + 3 = 6
Group 3: 0 + 0 + 0 = 0
Sample 3
Given the following sample fields:
        Number  |
        Arbitrary  |
        Negative Values  |
        Positive Values  |
        One  |
        Binary  |
        Currency  |
        Decimal  |
        1  |
        3  |
        -1  |
        1  |
        1  |
        0  |
        $1.00  |
        1.01  |
        2  |
        2  |
        -2  |
        2  |
        1  |
        $10.00  |
        2.02  |
        3  |
        1  |
        -3  |
        3  |
        0  |
        $100.00  |
        3.03  |
        4  |
        0  |
        -4  |
        4  |
        1  |
        $1,000.00  |
        4.04  |
        5  |
        -1  |
        -5  |
        5  |
        0  |
        $10,000.00  |
        5.05  |
        6  |
        -2  |
        -6  |
        6  |
        1  |
        -$1.00  |
        6.06  |
        7  |
        -3  |
        -7  |
        7  |
        0  |
        -$10.00  |
        7.07  |
        8  |
        0  |
        -8  |
        8  |
        -$100.00  |
        8.08  |
        9  |
        0  |
        -9  |
        9  |
        -$1,000.00  |
        9.09  |
        10  |
        0  |
        -10  |
        0  |
        $0.00  |
        0.00  |
Sample fields.
Abs Results:
        Number  |
        Arbitrary  |
        Negative Values  |
        Positive Values  |
        One  |
        Binary  |
        Currency  |
        Decimal  |
        55  |
        12  |
        55  |
        45  |
        1  |
        3  |
        12,222.00  |
        45.45  |
The results per field.
