Abs Sum
The absolute of the sum of the selection.
This method returns the absolute value of the sum of each item in a set of numbers.
Sample 1
Given a list of arbitrary numbers:
    Arbitrary  |
    3  |
    2  |
    1  |
    0  |
    -1  |
    -2  |
    -3  |
    0  |
    0  |
    0  |
A list of positive and negative numbers
1. Compute for the sum of the values.
    Arbitrary  |
    0  |
The sum of all values.
2. Compute the absolute of zero, which equals zero.
Sample 2
Assuming that the same list of numbers has multiple groupings or breakdowns as shown below:
    Grouping  |
    Arbitrary  |
    1  |
    3  |
    1  |
    2  |
    1  |
    1  |
    1  |
    0  |
    2  |
    -1  |
    2  |
    -2  |
    2  |
    -3  |
    3  |
    0  |
    3  |
    0  |
    3  |
    0  |
The list of values with grouping.
1. Compute the sum of the numbers based on the grouping.
    Grouping  |
    Arbitrary  |
    1  |
    6  |
    2  |
    -6  |
    3  |
    0  |
The sum of values per grouping.
Computation Details:
Group 1: 3 + 2 + 1 + 0 = 6
Group 2: -1 + -2 + -3 = -6
Group 3: 0 + 0 + 0 = 0
2. Compute the absolute value of the summed-up numbers above.
    Grouping  |
    Arbitrary  |
    1  |
    6  |
    2  |
    6  |
    3  |
    0  |
Final result.
Sample 3
Given the following sample fields:
    Number  |
    Arbitrary  |
    Negative Values  |
    Positive Values  |
    One  |
    Binary  |
    Currency  |
    Decimal  |
    1  |
    3  |
    -1  |
    1  |
    1  |
    0  |
    $1.00  |
    1.01  |
    2  |
    2  |
    -2  |
    2  |
    1  |
    $10.00  |
    2.02  |
    3  |
    1  |
    -3  |
    3  |
    0  |
    $100.00  |
    3.03  |
    4  |
    0  |
    -4  |
    4  |
    1  |
    $1,000.00  |
    4.04  |
    5  |
    -1  |
    -5  |
    5  |
    0  |
    $10,000.00  |
    5.05  |
    6  |
    -2  |
    -6  |
    6  |
    1  |
    -$1.00  |
    6.06  |
    7  |
    -3  |
    -7  |
    7  |
    0  |
    -$10.00  |
    7.07  |
    8  |
    0  |
    -8  |
    8  |
    -$100.00  |
    8.08  |
    9  |
    0  |
    -9  |
    9  |
    -$1,000.00  |
    9.09  |
    10  |
    0  |
    -10  |
    0  |
    $0.00  |
    0.00  |
Sample fields.
AbsSum Results:
    Number  |
    Arbitrary  |
    Negative Values  |
    Positive Values  |
    One  |
    Binary  |
    Currency  |
    Decimal  |
    55  |
    0  |
    55  |
    45  |
    1  |
    3  |
    10,000.00  |
    45.45  |
The results per field.
