Do Not Aggregate
Returns the value of a single row, otherwise null.
This method can be used to display a source table.
Below is a source table showing two fields Number and Arbitrary, with Aggregation set to DoNotAggregate and grouped by the Row field. This means Row is also the Breakdown field.
    Row  |
    Number  |
    Arbitrary  |
    A  |
    1  |
    3  |
    B  |
    2  |
    2  |
    C  |
    3  |
    1  |
    D  |
    4  |
    0  |
    E  |
    5  |
    -1  |
    F  |
    6  |
    -2  |
    G  |
    7  |
    -3  |
    H  |
    8  |
    0  |
    I  |
    9  |
    0  |
    J  |
    10  |
    0  |
Sample table
If there are multiple items or rows without any grouping, then the value of the method is just n/a.
