Min
The minimum value from the selection.
Returns the minimum value in each set of numbers.
Sample 1
Given the following sample fields:
    Number  |
    Arbitrary  |
    Negative Values  |
    Positive Values  |
    One  |
    Binary  |
    Currency  |
    Decimal  |
    1  |
    3  |
    -1  |
    1  |
    1  |
    0  |
    $1.00  |
    1.01  |
    2  |
    2  |
    -2  |
    2  |
    1  |
    $10.00  |
    2.02  |
    3  |
    1  |
    -3  |
    3  |
    0  |
    $100.00  |
    3.03  |
    4  |
    0  |
    -4  |
    4  |
    1  |
    $1,000.00  |
    4.04  |
    5  |
    -1  |
    -5  |
    5  |
    0  |
    $10,000.00  |
    5.05  |
    6  |
    -2  |
    -6  |
    6  |
    1  |
    -$1.00  |
    6.06  |
    7  |
    -3  |
    -7  |
    7  |
    0  |
    -$10.00  |
    7.07  |
    8  |
    0  |
    -8  |
    8  |
    -$100.00  |
    8.08  |
    9  |
    0  |
    -9  |
    9  |
    -$1,000.00  |
    9.09  |
    10  |
    0  |
    -10  |
    0  |
    $0.00  |
    0.00  |
Sample fields.
The minimum value for each field in the table:
    Number  |
    Arbitrary  |
    Negative Values  |
    Positive Values  |
    One  |
    Binary  |
    Currency  |
    Decimal  |
    1  |
    -3  |
    -10  |
    0  |
    1  |
    0  |
    $0.00  |
    0.00  |
The results per field.
