Stdev
The Standard Deviation of the selection.
The Standard Deviation is a measure of how spread-out numbers are in a set. The Deviation just means how far from the normal.
Stdev is used when the group of numbers being evaluated is only a partial sampling of the whole population.
The formula:
Where
 is the
	 mean computed by getting the sum of all the items and dividing them
	 by the number of items minus one.
Sample 1
Given a set of numbers like 12, 6, 12.
1. Compute the mean of the sample.
Mean = (Sum of items/n), where n is the number of items
12+6+12/3=10
2. Square the difference between each point and the mean
(12-10)^2 =4
(6-10)^2 =16
(12-10)^2 =4
3. Calculate the average of the results in step 2 above
4+16+4/3-1=24/2
4. Compute the square root of the result in step 4.
√12 or 3.4641
Sample 2:
Given the following sample fields:
    Number  |
    Arbitrary  |
    Negative Values  |
    Positive Values  |
    One  |
    Binary  |
    Currency  |
    Decimal  |
    1  |
    3  |
    -1  |
    1  |
    1  |
    0  |
    $1.00  |
    1.01  |
    2  |
    2  |
    -2  |
    2  |
    1  |
    $10.00  |
    2.02  |
    3  |
    1  |
    -3  |
    3  |
    0  |
    $100.00  |
    3.03  |
    4  |
    0  |
    -4  |
    4  |
    1  |
    $1,000.00  |
    4.04  |
    5  |
    -1  |
    -5  |
    5  |
    0  |
    $10,000.00  |
    5.05  |
    6  |
    -2  |
    -6  |
    6  |
    1  |
    -$1.00  |
    6.06  |
    7  |
    -3  |
    -7  |
    7  |
    0  |
    -$10.00  |
    7.07  |
    8  |
    0  |
    -8  |
    8  |
    -$100.00  |
    8.08  |
    9  |
    0  |
    -9  |
    9  |
    -$1,000.00  |
    9.09  |
    10  |
    0  |
    -10  |
    0  |
    $0.00  |
    0.00  |
Sample fields.
The Stdev for each field:
    Number  |
    Arbitrary  |
    Negative Values  |
    Positive Values  |
    One  |
    Binary  |
    Currency  |
    Decimal  |
    3.0277  |
    1.7638  |
    3.0277  |
    3.0277  |
    0  |
    .5345  |
    $3,197.5720  |
    3.0579  |
The results per field.
