Stdevp
The Population Standard Deviation of the selection.
The Stdevp deals with the complete population whereas Stdev deals with a population sample only.
The formula:
Sample 1:
Population: A set of data that is all inclusive.
Populations are often very large. For simplicity, imagine the following as an example:
12,6,12
Compute the Stdevp:
1. Determine the mean of the sample
12+6+12/3=10
2. Square the difference between each item and the mean
(12-10)^2 =4
(6-10)^2 =16
(12-10)^2 =4
3. Calculate the average
4+16+4/3=24/3
4. Calculate the square root
√8 or 2.8284
Sample 2
Given the following sample fields:
    Number  |
    Arbitrary  |
    Negative Values  |
    Positive Values  |
    One  |
    Binary  |
    Currency  |
    Decimal  |
    1  |
    3  |
    -1  |
    1  |
    1  |
    0  |
    $1.00  |
    1.01  |
    2  |
    2  |
    -2  |
    2  |
    1  |
    $10.00  |
    2.02  |
    3  |
    1  |
    -3  |
    3  |
    0  |
    $100.00  |
    3.03  |
    4  |
    0  |
    -4  |
    4  |
    1  |
    $1,000.00  |
    4.04  |
    5  |
    -1  |
    -5  |
    5  |
    0  |
    $10,000.00  |
    5.05  |
    6  |
    -2  |
    -6  |
    6  |
    1  |
    -$1.00  |
    6.06  |
    7  |
    -3  |
    -7  |
    7  |
    0  |
    -$10.00  |
    7.07  |
    8  |
    0  |
    -8  |
    8  |
    -$100.00  |
    8.08  |
    9  |
    0  |
    -9  |
    9  |
    -$1,000.00  |
    9.09  |
    10  |
    0  |
    -10  |
    0  |
    $0.00  |
    0.00  |
Sample fields.
The Stdevp for each field:
    Number  |
    Arbitrary  |
    Negative Values  |
    Positive Values  |
    One  |
    Binary  |
    Currency  |
    Decimal  |
    2.8723  |
    1.6733  |
    2.8723  |
    2.8723  |
    0  |
    0.4949  |
    $3,033.4832  |
    2.9010  |
The results per field.
