Scatter Plot Settings
Scatter Plots are used to identify trends, clustering and outliers across a number of numeric variables, especially when investigating large data volumes.
Each scatter point is represented by:
q X Position
q Y Position
q Size
q Color (numeric or categorical)
A line of best fit can also be added to highlight outliers.
Panopticon's Scatter Plot data visualizations are easy to set up and highly customizable. You can configure your display in ways that will make the most sense to you and your users, and users have all the tools they need to filter and manipulate the Scatter Plot to concentrate on the most relevant subsets in the data.
The scatter plot settings pane
is displayed after clicking
the Options
button.
Setting |
Description |
Show Borders |
Determines whether a border is drawn around each scatter point. |
Show Best Fit Line |
Determines whether a Line of Best Fit is added to the Scatter Plot. |
Show Labels |
Determines whether labels will be displayed. If enabled, select how scatter point labels are shown: · Distinguishable · All |
Min Radius |
The minimum radius in pixels of the scatter point. |
Max Radius |
The maximum radius in pixels of the scatter point. |
Show Line |
Determines whether to plot lines between two positions or dots on the scatter plot. Enables the Line Width and Line Color properties. |
Line Width |
Width of the plot line. |
Line Color |
Color of the plot line: · Use Variable - colors can be specified for the elements in the visualization through the Color variable. · Custom Color – displays the Custom Color section. |
Show Arrows |
Determines whether to display arrows to indicate where lines start and end. |
Arrow Offset |
Where the arrows will be positioned in the lines · 0 - start · 0.5 - middle · 1 - end |
Background Image |
Defines that a background image is displayed behind the scatter plot. You can either: · click Resource · click URL
Legacy Shape |
Allows older workbooks to be updated and use the shape variable. Default is Use Variable. Other shapes can also be selected. |
Show Coordinates |
Determines whether the graph coordinates (i.e., X-Y plots, or Date/Time-Y plots) on mouse over are displayed in the visualization. |
Other visualization-specific properties can be set by clicking on the X-Axis variable drop area and then selecting the X-Axis tab:
Or also, by clicking on the Y-Axis variable drop area and then selecting the Y-Axis tab:
then
Choose File
and
select the background image in the Open dialog that
displays.
and
enter the URL of the image file. This value can be parameterized
and use Snapshot and retrieve the image upon each parameter
value change.
