Line Graph Settings
Line Graphs are easy to understand and are a great way to communicate important time-based trends, clustering, and outliers.
They work especially well when comparing ten or fewer data sets (our Horizon Graph is a good solution for displaying time series data with ten or more data sets).
The line graph
	 settings pane is displayed after clicking the Options
 button.
    Setting  |
    Description  |
    Line Width  |
    Specifies the line width in pixels.  |
    Dot Radius  |
    Specifies the radius of each data point in pixels.  |
    Dash Pattern  |
    Specifies the line pattern. Available options are: · Dotted · Dashed · Solid  |
    Line Interpolation  |
    Specifies whether the line is Stepped, Linear, or Smooth Interpolation.  |
    Value Interpolation Time Gaps  |
    Determines whether time axis gaps (Working Week/Time) are interpolated.  |
    Value Interpolation Na Value Gaps  |
    Determines whether Na value (or missing) gaps are interpolated.  |
    Shade Area Below Line  |
    Defines that opacity shades are applied between the lines and the zero Y grid line.  |
    Shade Area Opacity (%)  |
    Specifies the opacity (transparency) of the shaded area, expressed in percent 0-100 of the opacity value currently set on the line.  |
    Show Last Value  |
    Determines if the flag of the last value will be displayed. Once enabled, the Y-Axis Alignment settings section displays.
 ·         Select  ·         Select  · Enter the Last Value Margin. Default is 80. · Check the Show Last Value Title box to display the title of the last value in the flag.  |
    Show Coordinates  |
    Determines whether the graph coordinates (i.e., X-Y plots, or Date/Time-Y plots) on mouse over are displayed in the visualization.  |
Other visualization-specific properties can be set by clicking on the Y-Axis variable drop area and then selecting the Y-Axis tab:
    Setting  |
    Description  |
    Independent Y-Axis Scaling  |
    Determines whether to have each visualization Y-axis in a cross tab automatically scaled independent of the others.  |
 to
			 display Y-axis on the left side.
 to
			 display the Y-axis on the right side.
