Connector for Apache Cassandra
The Apache Cassandra connector allows connection to Apache and Datastax Cassandra instances, by executing a pre-defined CQL query, and retrieving the resulting data.
1. Enter the following information:
    Property  |
    Description  |
    Host  |
    Apache Cassandra host address.  |
    Port  |
    Apache Cassandra host port. Default is 9042.  |
    KeySpace  |
    Namespace that defines data replication in nodes.  |
    User Id  |
    The username used to connect to the Apache Cassandra service.  |
    Password  |
    The password used to connect to the Apache Cassandra service.  |
2. Select whether the parameters should be automatically enclosed in quotes, by checking the Enclose parameters in quotes box.
3. Enter the CQL Query, which can contain parameters in a similar manner to the database connector.
4. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
