Connector for InfluxDB
The InfluxDB connector allows for the retrieval of a JSON data set from the InfluxDB. The database communicates over HTTP(S) where you can define a query in the URL to return the desired data.
1. Enter the following information:
    Property  |
    Description  |
    URL  |
    InfluxDB host address.  |
    Port  |
    InfluxDB host port. Default is 8086.  |
    User Id  |
    The user Id that will be used to connect to the InfluxDB service.  |
    Password  |
    The password to connect to the InfluxDB service. Check the Show Characters box to display the entered characters.  |
    Database  |
    The name of the database that will communicate over the HTTP(S).  |
    Time out (Secs)  |
    The time out period applied to both the TCP socket and for individual read IO operations. Default is 10.  |
2. Enter an SQL-like query language into the Query box.
3. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
