Connector for Splunk
The Splunk connector allows the retrieval of data from a Splunk instance.
1. Enter the following properties:
    Property  |
    Description  |
    Host  |
    Splunk host address.  |
    Port  |
    Splunk host port. Default is 8089.  |
    User Id  |
    The user Id that will be used to connect to the Splunk service.  |
    Password  |
    The password that will be used to connect to the Splunk service.  |
2. Select the Search Type:
· Manual
Proceed to step 6 to define a new search query.
· Saved Search
Allows you to select in the Saved Search drop-down list.
3.     Click
 to populate the Application
	 drop-down list and select one.
4. Select whether the parameters should be automatically enclosed in quotes by checking the Enclose parameters in quotes box.
5. Enter a Search Query.
