Connector for StreamBase LiveView
The StreamBase LiveView connector allows connection to the StreamBase LiveView instance on a real-time streaming basis.
    NOTE  |
    Supported Java versions must be earlier than 255. For example, if you are using JDK or JRE, it should be less than 1.8.0_255.  |
1. Enter the following properties:
    Property  |
    Description  |
    Primary URL  |
    Primary URL of the StreamBase LiveView. Default is lv://localhost:10080/.  |
    User Id  |
    User Id that will be used to connect to StreamBase LiveView.  |
    Password  |
    Password that will be used to connect to StreamBase LiveView.  |
2. Do one of the following:
·         Select the Table radio button
	 then click
 to return a list of updated
	 Tables, or
Select the required table.
By default, the whole table will be subscribed against. To subscribe against a subset, enter a predicate.
The IN syntax is recommended for use of parameters to support multiple values. The square bracket notation should be used for the INclause.
Example: color IN [{color}]
·         Select the Query radio button,
	 enter a full query, then click
3. Select whether the parameters should be automatically enclosed in quotes by checking the Enclose parameters in quotes box.
4. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
5. Enter the Id Column Name.
LiveView supplies a unique Id for each row. This Id field is by default given a title of Key.
6. For this section:
Refer to Define Real-Time Settings for more information.
