Creating a New Sign Color Palette
The Sign color palette is used to signify the positive or negative values in numeric visual members.
1. On the Sign section, click the
Add Palette
icon.
The New Sign Palette dialog displays.
2. Enter the Title then click
3. To set the Positive Color (default is Gray) and the Negative Color (default is Red), click the Color box to display the Color dialog and select the palette color or enter the Hex color code.
4. Click
The new Sign color palette is added in the list. Note that it is already included and can be modified, duplicated, and deleted.
