DiodeCenterTap2mPulse
2*m pulse diode rectifier with center tap
Modelica/Electrical/PowerConverters/ACDC
General information about AC/DC converters can be found at theAC/DC converter concept
This is a 2*m pulse diode rectifier with center tap. In order to operate this rectifier a voltage source with center tap is required. The center tap has to be connected with the negative pin of the load. The circuit topology is the same as inExamples.ACDC.RectifierCenterTap2mPulse.
mo_RonDiode | RonDiode | Closed diode resistance | Scalar | |
mo_GoffDiode | GoffDiode | Opened diode conductance | Scalar | |
mo_VkneeDiode | VkneeDiode | Diode forward threshold voltage | Scalar | |
mo_T | T | Fixed device temperature if useHeatPort = false | Scalar | |
mo_T_heatPort | T_heatPort | T_heatPort | Structure | |
mo_T_heatPort/fixed | fixed | Cell of scalars | true | |
mo_T_heatPort/start | start | Cell of scalars |
mo__modifiers/varname | Variable name | Cell of strings | 'vAC' | |
mo__modifiers/value | Value |
ac_p | implicit | Positive potential AC input | input | 1 |
ac_n | implicit | Negative potential AC input | output | 1 |
dc_p | implicit | Positive DC output | input | 2 |
Port 4 | implicit | Conditional heat port | input | mo_useHeatPort |
