Altair® Panopticon™
Adding Calculated Columns
   NOTE
·           User defined columns can only be added when there is an available data source.
·           The user-defined columns are added in the topmost data source in the Data Sources list or in the joined or combined data source.
·           An auto key can only be created once.
·           Ranking requires a numeric source column.
·           Time bucketing requires a time source column and each source column can only be used once.
·           Numeric bucketing requires a numeric source column.
·           Text grouping requires a text source column.
·           The added user-defined column displays on the Data Preview with a pen symbol  which allows its modification.
