Altair® Panopticon™
Modification of the Column Names
The name of columns retrieved from the data source can be modified.
1.     On the Data Sources panel, click a data source to display its settings.
2.     Click Columns. The Columns pane displays the list of available columns in the data source.
3.     Select the column name that you want to modify, then enter the new name and click .
Once the column name is modified, the button is displayed. Click this button to revert to the original column name.
4.     Click . The new column names are displayed on the Data Preview.
