Altair® Panopticon™
Working with the General Settings
Every visualization has these general settings:
Property
Title
Title of the visualization. Can be more than one displayed in multiple rows.
Add Title Row
Click to add more title rows. Settings for each title row can be done in the Style section.
Dashboard Part ID
The ID of the dashboard part.
Header Controls
Displays header controls such as Export Excel, Toggle Display Mode, Maximize, Rubber Band Zoom, and Rubber Band Selection. Can either be Floating (default),  Fixed, or disabled.
Enable Shelves
Tab the slider to enable the shelves settings (i.e., Shelves and Visible Shelves) and display Show Shelves in the context menu.
Shelves
Tap the slider to display the Shelf Variable and Breakdown.
Visible Shelves
Check the boxes of the shelves that will be displayed in the visualization.
Double click mode
Sets the behavior to be performed when double-clicking on a visualization value.
Zoom
Enable to reset the zoom on data reload.
Automatic Parameterization
Select the automatic parameterization status: On, Off, or Inherit (default).
Data Table
Allows you to switch to another data table in the workbook to be used in the visualization.
Recalculate Automatic Range on Breakdown Change
Tap the slider for variables with automatic range/mapping to be recalculated when the visible depth is changed in the visualization.
Help Text
The added Help text can be displayed for the visualization.
