Altair® Panopticon™
Moving a Data Table to Data Library
A data table that was created in the Workbook Internal Data Table Editor can be moved to the Data Library.
1.     Click the Move to Data Library   icon of a data table in the Data Tables list.
The Publish Data Table dialog displays.
2.     You can opt to enter a new Name of the published data table.
3.     Select the folder or subfolder where the data table  will be published .
4.     Click .
The moved notification message displays.
   NOTE
·        The data table is removed from the Data Tables pane in the Workbook Internal Data Table Editor.
·        The original data table is removed from the workbook and replaced with a linked data table, pointing to the data library.
