Altair® Panopticon™
Combinations
Returns how many distinct combinations of breakdown column values there are below each node in the hierarchy.
Given this data table:
Region
Country
1 Day Change % (USD)
Mcap Rank
1 Month Change % (USD)
Europe
AT
-7.4%
32
71.31%
Europe
AT
-6.56%
68
51.07%
Europe
AT
-2.78%
66
-17.28%
Asia Pacific
AU
-0.72%
57
22.35%
Asia Pacific
AU
3.28%
72
13.99%
Europe
BE
-4.94%
45
49.33%
Europe
BE
-9.23%
48
78.89%
Europe
BE
4.19%
28
22.68%
Europe
BE
-2.63%
51
22.60%
North America
CA
-5.19%
25
13.82
North America
CA
12.19%
41
19.11%
North America
CA
1.20%
16
17.14%
Sample 1
Below is the defined breakdown in a Table visualization:
Adding 1 Day Change % (USD) column to the Records variable will produce the following table with the aggregate set to Sum (default):
Asia Pacific
AU
0.03
Europe
AT
-0.17
BE
-0.13
North America
CA
0.08
Changing the aggregate of 1 Day Change % (USD) to Count will display how many instances of 1 Day Change % (USD) (rows from the data table) there are in each country:
Asia Pacific
AU
2
Europe
AT
3
BE
4
North America
CA
3
Adding Mcap Rank to the Records variable will result to the following table with the aggregate set to Sum (default):
Mcap Rank
Asia Pacific
AU
2
129
Europe
AT
3
166
BE
4
172
North America
CA
3
82
Changing the aggregate of Mcap Rank to Combinations will display how many countries (rows in fully expanded visual table) there are.
Mcap Rank
Asia Pacific
AU
2
1
Europe
AT
3
1
BE
4
1
North America
CA
3
1
Changing the visible depth in the breakdown to Region should show:
Mcap Rank
Asia Pacific
2
1
Europe
7
2
North America
3
1
Asia Pacific has 1 (AU), Europe has 2 (AT and BE), and North America has 1 (CA).
