Altair® Panopticon™
Include/Exclude List
This filter mode allows to include or exclude a set of values from a given column. It consists of a Free Text filter used for finding values to include or exclude and a list of values that are currently used in the filter.
Set the Suggestion List Max Size with the custom limit on how many options/suggestions should be, at the most, loaded and presented on the drop-down. Default is 10.
   NOTE
There is no Select All option. When there is no value, this means no filtering will be done in both the Include or Exclude mode.
When entering a value, matches are displayed allowing you to pick one from the list.
The selected column value is displayed under the Include/Exclude button.
For the example above, the column value is included in the filter.
Click to exclude this column value in the filter,
Click  to delete a column value from the Include/Exclude list.
