Altair® Panopticon™
Drilling into Visualizations
Visualizations themselves can be used to drill into lower or upper details by selecting items, and right-clicking to display the context menu with three options:
q  Drill Down – Drills down to the lower level of the selected value.
   NOTE
Drilling without filter (or soft drill) is turned on for all aggregates that refer to:
·         Nodes above the node like the parent or root
·         Siblings of the node
Applicable to the following aggregates in the Aggregate drop-down list:
·         Sibling Rank
·         Percent of Total
·         Percent of Total Reference
·         Percent of Parent
·         Percent of Parent Reference
·         Percent of Total Change
·         Cumulative Sum
·         Cumulative Sum By Max
q  Drill Up – Enabled when the lower level of the selected item is displayed. Click to drill to the upper level.
q  Drill to Top – Drills to the top level of the selected value.
Drilling into visualizations can also be done by double-clicking on a value. Refer to Double Click Mode Options for more information.
