Altair® Panopticon™
Connector for JSON
The JSON connector allows the retrieval and processing of JSON files, either from a disk, a Text, or from a defined URL.
The supported JSON structures are discussed here.
1.     Select the JSON File Source.
2.     Enter the Record Path which allows the identification of multiple records within the JSON document (e.g., myroot.items.item). This property can be parameterized.
3.     Select either the dot (.) or comma (,) as the Decimal Separator.
4.     Click  to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
5.     You can also opt to load or save a copy of the column definition.
6.      Set the File Encoding to use:
·        UTF-8
·        UTF-16
·        UTF-32
·        US-ASCII
·        Windows-1252
7.     Click to add columns and specify their properties:
Property
Name
Json Path
The Json Path of the source schema.
Date Format
Enabled
Determines whether the message field should be processed.
To delete a column, check its  or all the column entries, check the topmost , then click .
8.     Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
