Altair® Panopticon™
Connector for InfluxDB
The InfluxDB connector allows for the retrieval of a JSON data set from the InfluxDB. The database communicates over HTTP(S) where you can define a query in the URL to return the desired data.
1.     Enter the following information:
Property
URL
InfluxDB host address.
Port
InfluxDB host port. Default is 8086.
User Id
The user Id that will be used to connect to the InfluxDB service.
Password
The password to connect to the InfluxDB service.
Check the Show Characters box to display the entered characters.
Database
The name of the database that will communicate over the HTTP(S).
Time out (Secs)
The time out period applied to both the TCP socket and for individual read IO operations. Default is 10.
2.     Enter an SQL-like query language into the Query box.
3.     Date/Time values of output data and Date/Time inputs, where supported, are by default unchanged.
