Altair® Panopticon™
Connector for Google Cloud Pub/Sub
The Google Cloud Pub/Sub connector allows connection to Google Cloud Pub/Sub’s message bus on a real-time streaming basis. Specifically, the connector allows Panopticon to subscribe to XML, JSON, TEXT or FIX based messages that are published on topics. The data format itself is arbitrary, and consequently, the connection includes the message definition.
1.     Enter the Service Account Credential JSON Text with the generated JSON key (contains the private key) in the following format:
{ "type": "service_account", "project_id": "project-id", "private_key_id": "some_number", "private_key": "-----BEGIN PRIVATE KEY-----\n.... =\n-----END PRIVATE KEY-----\n", "client_email": "<api-name>api@project-id.iam.gserviceaccount.com", "client_id": "...", "auth_uri": "https://accounts.google.com/o/oauth2/auth", "token_uri": "https://accounts.google.com/o/oauth2/token", "auth_provider_x509_cert_url": "https://www.googleapis.com/oauth2/v1/certs", "client_x509_cert_url": "https://www.googleapis.com/...<api-name>api%40project-id.iam.gserviceaccount.com" }
   NOTE
Ensure that when parameterizing the values in the Credential JSON Text, there is no white space as a single line content.
2.     Click  to populate the Topic drop-down list. Initially, the first topic in the list is displayed in the Topic drop-down box.
Select a topic.
3.     Click  to populate the Subscription Name drop-down list and select a subscription name.
You can also opt to create a subscription by manually entering the value into the Subscription Name list box.
   NOTE
·           A subscription name will be automatically generated when it is not entered or selected in the drop-down list.
This subscription will be created for connection and will be deleted as soon as its work is done. For example, when starting a presentation mode, a subscription will be created. Upon quitting the presentation mode, the subscription will then be deleted.
·           Pub/Sub can automatically delete inactive subscriptions. This can be done by configuring the minimum required time of inactivity to schedule a subscription for deletion. This time must be longer than the message retention duration.
4.     Select the Message Type.
5.     Select either the dot (.) or comma (,) as the Decimal Separator.
6.     Click  to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
This also populates the Id Column with the set of columns, of arbitrary type, that can be concatenated to form a unique row identifier.
7.     You can also opt to load or save a copy of the column definition.
8.   Click to  add columns to the Google Cloud PubSub connection that will represent sections of the message.
9.   Provide the following information:
Property
Name
Fix Tag/XPath/Column Index/Json Path
The Fix Tag/XPath/Column Index/Json Path of the source schema.
Date Format
Enabled
Determines whether the message field should be processed.
To delete a column, check its  or all the column entries, check the topmost , then click .
10.   Google Cloud Pub/Sub messages can have additional metadata as custom attributes.
Panopticon Google Cloud Pub/Sub connector supports reading these attributes as column values. The generate column logic automatically checks and generates attribute columns if messages received contain attributes.
Additionally, like columns from message data, you can manually add them by clicking . A new entry displays.
Name can be any unique column name within the data source. The attribute name must match an attribute name in message otherwise it will be treated as null value.  Currently all attribute columns are treated as Text columns, we can't change column type.
Check the Enabled box to enable an attribute column.
11.   Date/Time values of output data and Date/Time inputs, where supported, are by default unchanged.
12.   For this section:
Refer to Define Real-Time Settings for more information.
