Altair® Panopticon™
Connector for MQTT
The MQTT connector allows:
q  connection to MQTT’s message bus on a real-time streaming basis.
q  Panopticon to subscribe to FIX, JSON, Text, or XML based messages that are published on topics. The data format itself is arbitrary, and consequently, the connection includes the message definition.
q  encrypted/SSL connections using a generated CA certificate file.
1.     Enter the following properties:
Property
Broker URL
The location of the message broker. Default is tcp://localhost:1883
Topic
The topic or the queue physical name.
Example:
level1/level2/level3/level4 etc.
NOTES:
You can also opt to use a wild card in the topic name specification.
·         The plus sign symbol (+) can be used as a wild card for any value at one specific level.
Example: level1/level2/+/level4
·         The hash sign symbol (#) can be used as a wild card for any values across more than one level.
Example: level1/#/level4
User Id
The user Id that will be used to connect to MQTT.
Password
The password that will be used to connect to MQTT.
2.     To allow encrypted connections, you can either:
·         Upload a CA Certificate file by clicking Upload File  then Browse   to browse to the file source.
After selecting the file, it is displayed with the timestamp.
To change the certificate, click  then Browse  to browse to a new version of the file.
·         Link to a CA Certificate file by clicking Link to File   and entering the File Path.
3.     In MQTT, a topic consists of one or more topic levels. Enter the Topic Level Separator to use. Default is / (forward slash).
4.     Select the Message Type. This will specify the format of the data within the message:
5.     Select either the dot (.) or comma (,) as the Decimal Separator.
   NOTE
Prepend 'default:' for the elements falling under default namespace.
6.     Click  to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
This also populates the Id Column with the set of columns, of arbitrary type, that can be concatenated to form a unique row identifier.
7.    You can also opt to load or save a copy of the column definition.
8.    Click  to add columns to the MQTT connection that represent sections of the message. Then enter or select:
Property
Name
XPath/JsonPath/Fix Tag/Column Index
The XPath/JsonPath/Fix Tag/Column Index of the source schema.
Date Format
NOTE:
To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them.
For example: yyyy-MM-dd HH:mm:ss.SSSSSS
Filter
Defined parameters that can be used as filter. Only available for JSON, Text, and XML message types.
Enabled
Determines whether the message field should be processed.
To delete a column, check its  or all the column entries, check the topmost , then click .
9.   Text for topic levels can be consumed as additional columns into the data table.
The Topic Columns section shows and allows defining data table columns and mapping them to topic hierarchy levels (index based on left, 0 based).
Like columns from message data, manually add them by clicking . A new entry displays.
Name can be any unique topic level within the topic name. The Level is the hierarchy level of the topic column.
Check the Enabled box to enable a topic column.
10.   Date/Time values of output data and Date/Time inputs, where supported, are by default unchanged.
11.   For this section:
Refer to Define Real-Time Settings for more information.
