Altair® Panopticon™
Creating a New Shape Palette in a Workbook
1.     Click Add Palette .
A new shape palette displays (i.e., ShapePalette.0).
2.     Click ShapePalette.<Number>.
The section expands to allow its definition.
3.     Enter the shape palette Title and click .
4.     To make this shape palette the default for the workbook theme, tap the Default Palette slider to turn it on.
   NOTE
The default shape palette can not be deleted.
5.     To add the shapes, click  .
You can either:
·         click on a shape.
·         click . Select one or more SVG files in the Open dialog box that displays.
The added shapes are displayed.
To delete a shape, click it’s corresponding Delete icon.
6.     Select the Default Shape in the drop-down list.
7.     Click the Save  icon on the toolbar.
8.     When saved, the  notification is displayed.
The new shape palette is available in the Shape Palette drop-down list in the Shape variable when the workbook theme, where it is added, is used (i.e., Light).
