Altair® Panopticon™
Creating a New Text Color Palette
The configuration pane for the Color variable changes depending on the column data type.
In the Web Authoring, when a text column is added to the Color variable, the configuration pane displays the color associated with each categorical item, as specified with a default color palette (e.g., Twenty Eight Colors).
1.     On the Text section, click the  Add Palette  icon.
The Next Text Palette dialog displays.
2.     Enter the Title then click .
3.     Select the Number of Colors in the drop-down list. Default is 28 colors.
The Other list is updated accordingly.
4.    To set the colors, you can do one of the following:
·        Click the Color box to display the Color dialog and set the Hex color code, RGB, or HSL value
·        Enter the Hex color code
·        Enter the HTML color name
5.     Click .
The new text color palette is added in the list (e.g., Sixteen Colors). Note that it can be deleted.
