Encrypting Passwords in tomcat-users.xml
Tomcat supports encrypted user credentials via the Digested Passwords feature:
https://tomcat.apache.org/tomcat-9.0-doc/realm-howto.html#Digested_Passwords
To secure passwords saved in tomcat-users.xml, do the following:
  1. Stop Tomcat.
  2. Open [tomcat_home]/conf/server.xml.
  3. In server.xml, find the Engine XML element.
    Nested inside the Engine element, there is a Realm element named LockOutRealm. Nested inside the LockOutRealm is another Realm element named UserDatabaseRealm that looks like this:
    <Realm className="org.apache.catalina.realm.UserDatabaseRealm"
           resourceName="UserDatabase"/>
  4. Edit the UserDatabaseRealm element into the following:
           resourceName="UserDatabase">
           <CredentialHandler className="org.apache.catalina.realm.MessageDigestCredentialHandler"
                              algorithm="SHA-256"/>
    </Realm>
    You must add the closing element “</Realm>” for the UserDatabaseRealm, and edit out the closing forward slash “/” at the end of the original Realm element.
  5. Generate hash from plain text passwords using the command below:
    Linux example:
    [tomcat_home]/bin/digest.sh -a SHA-256 -h org.apache.catalina.realm.MessageDigestCredentialHandler
    [password]
    Windows example:
    [tomcat_home]/bin/digest.bat -a SHA-256 -h org.apache.catalina.realm.MessageDigestCredentialHandler
    [password]
    If your Apache Tomcat installation has the JAVA_HOME environment variable set only in the file catalina.sh (Linux) or catalina.bat (Windows) and not generally on the system, you will also need to set the JAVA_HOME variable before running the digest command.
    Linux example:
    export JAVA_HOME=/path/to/JavaInstallation
    Windows example:
    set JAVA_HOME=/path/to/JavaInstallation
    The digest command will return the password supplied, followed by a colon, and then a hash of the password. Example, for a password asd123:
    asd123:74807befd6bdc1c937dc931a3dfadf015da1df1b99b74cd8d91210788e0141a5$1$f21cb2dd667209d639f6be48cf83826a657730032bdacb04465262d221bfc509
  6.  Replace the plain text password in tomcat-users.xml with the generated password hash, and save the tomcat-users.xml file. NOTE: When you have defined a MessageDigestCredentialHandler in the UserDatabaseRealm, then ALL passwords stored in tomcat-users.xml are treated as hash values. You will no longer be able to log in using passwords that are saved as clear text.
  7. Start Tomcat.
