Saving or Loading Column Definition in the Data Sources
Save or load column definitions in the data sources.
- Click
to save a copy of a column definitions file (.EXS). - Instead of generating columns, click
to load a column definitions (.EXS) file.
The Load Column Definitions dialog displays.
- To load column definitions, you can either:
- Drag it from your desktop and drop in the dialog, or
- Click Choose Column Definitions File to Load and select one in the Open dialog that displays.
The name of the column definitions is displayed on the loaded column definitions area.
- Click
A notification displays when the file is loaded.
This populates the list of columns from the .EXS file.
