Analyze the elasto-plastic stress gradients that build up across the surface of a
blank during forming and cause the blank to bounce back and deviate from the desired
shape.
From the ribbon, click the Add operation icon.
From the Add Operation window that appears, select
Springback.
The Springback operation is added to the Tryout
ribbon.
Note: By default, the software automatically identifies the part in
your model for the springback analysis.
Click the Springback operation.
Click
to add
Reference, Constraint,
Clamps, Pins, or
Gravity tools.
Configure the selected tools for the Springback
operation.
Optional:
Right-click
the Springback tool, then select
Explicit to change to Explicit
springback analysis mode. The tool uses
Implicitspringback analysis mode by
default.
Figure 1. Model Set Up to Analyze Springback of the Formed Shape
