Finite element modeling
Results visualization
Plotting and data analysis
Multi-body modeling
Video and image editing
Spreadsheet capabilities
Math script processing
Browsers provide a structured view of model data, which you can use to review, modify, create, and manage the contents of a model.
Create, edit, and cleanup topology.
Explore the different types of mesh you can create in HyperWorks and create and edit 0D, 1D, 2D, and 3D elements.
Design and optimize structures and mechanical systems.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
From the HyperGraph menu, select Line Chart to display the Line Chart ribbon.
From the HyperGraph menu, select Bar Chart to display the Bar Chart ribbon.
From the HyperGraph menu, select Complex Chart to display the Complex Chart ribbon.
From the HyperGraph menu, select Polar Chart to display the Polar Chart ribbon.
From the HyperGraph menu, select Polar Chart to display the Vector Plot ribbon.
From the HyperGraph menu, select Radar Chart to display the Radar Chart ribbon.
From the HyperGraph menu, select 3D Chart to display the 3D Chart ribbon. Manage, review, and analyze waterfall, surface, and 3D line data plots.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
Add an FMU to the model or export a model as an FMU.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
The user interface provides you with a consistent look and feel when you are working in any of the HyperWorks applications.
Trace key points and objects in your video and set up a tracking system on an object in the video.
Apply annotations, headers, and footers to your video.
Compare video frames or overlay frames with other videos or images to watch them in flips.
Load Excel CSV files into TableView.
Displays the data contained in the selected TableView cell.
Define value-dependent rules and apply them as attributes within the selected cells.
TableView supports overlaying reports for summary tables.
Shows or hides the table column headers and row numbers.
Refreshes the table data.
TableView supports cell math references in a Templex expression, like the support of curve math references in HyperGraph.
From TableView, use the Table Browser to view the current session and all pages and windows it contains in a hierarchical display.
From within a cell, row number, or column header in TableView, right-click to display the following context menu items.
Evaluation Mode Control turns text editing capabilities on and off.
From the Text Attributes panel, you can change the text and background colors as well as the font attributes.
Use the Find dialog to locate specific text.
Updates any text that references data in other windows, reflecting the referenced data's current state.
From TextView, use the Text Browser to view the current session and all pages and windows it contains in a hierarchical display.
Keyboard shortcuts are available in TextView.
