*airbagfoldingsequences()
Creates an airbagfoldingsequence in HMASCII format.
*airbagfoldingsequences (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the airbagfoldingsequence.
- name
- The name of the airbagfoldingsequence.
- color
- The color of the airbagfoldingsequence. Valid values are 1-64.
To create an airbagfoldingsequence with ID 100, name "my-entity", and color
1:
*airbagfoldingsequences(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.1
