*airbagfolds()
Creates an airbagfold in HMASCII format.
*airbagfolds (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the airbagfold.
- name
- The name of the airbagfold.
- color
- The color of the airbagfold. Valid values are 1-64.
To create an airbagfold with ID 100, name "my-entity", and color
1:
*airbagfolds(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.1
