*behaviors()
Creates a behavior in HMASCII format.
*behaviors() (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the behavior.
- name
- The name of the behavior.
- color
- The color of the behavior. Valid values are 1-64.
To create a behavior with ID 100, name "my-entity", and color
1:
*behaviors(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.1
