Creates an FBD force plot, and fields or loads from the results.
*fbdforce
freebodysection_ids data_strings num_strings
HyperMesh Tcl Modify Command
This queries the GPF, Applied, SPC and MPC data from the result entity on a
freebodysection.
- freebodysection_ids
- The list of freebodysection entity IDs.
- data_strings
- The ID of the string array that contains the additional input parameters. The string
array is created using the *createstringarray command. This should
always be set to 1.
- Valid parameters and their syntax are:
- appf=<value>
- 0 - Applied forces do not participate in the FBD calculation (default)
- 1 - Applied forces do participate in the FBD calculation
- arrlen=<value>
- Controls the FBD plot arrow length. Default is 75 (%).
- arroworigin=<value>
- 0 - Tail of arrow at node for the plot (default)
- 1 - Tip of arrow at node for the plot
- colorfx=<value>
- The color of the Fx arrow. Valid values are 1-64.
- colorfxy=<value>
- The color of the Fxy arrow. Valid values are 1-64.
- colorfxyz=<value>
- The color of the Fxyz arrow. Valid values are 1-64.
- colorfxz=<value>
- The color of the Fxz arrow. Valid values are 1-64.
- colorfy=<value>
- The color of the Fy arrow. Valid values are 1-64.
- colorfyz=<value>
- The color of the Fyz arrow. Valid values are 1-64.
- colorfz=<value>
- The color of the Fz arrow. Valid values are 1-64.
- colormx=<value>
- The color of the Mx arrow. Valid values are 1-64.
- colormxy=<value>
- The color of the Mxy arrow. Valid values are 1-64.
- colormxyz=<value>
- The color of the Mxyz arrow. Valid values are 1-64.
- colormxz=<value>
- The color of the Mxz arrow. Valid values are 1-64.
- colormy=<value>
- The color of the My arrow. Valid values are 1-64.
- colormyz=<value>
- The color of the Myz arrow. Valid values are 1-64.
- colormz=<value>
- The color of the Mz arrow. Valid values are 1-64.
- createfield=<value>
- 0 - Do not create a nodal force and moment field (default)
- 1 - Create a nodal force and moment field
- createload=<value>
- 0 - Do not create FBD force and moment loads (default)
- 1 - Create FBD force and moment loads
- declim=<value>
- Controls the decimal limit. Default is 2.
- display=<value>
- 0 - Do not plot FBD forces
- 1 - Plot FBD forces (default)
- freenode=<value>
- 0 - Free nodes. Find the nodes shared by elements other than the elements in
the freebodysection (default).
- 1 - Boundary nodes. Find only te boundary nodes of the elements in the
freebodysection.
- 2 - All nodes. Considers all nodes of the elements in the freebodysection.
- fx=<value>
- 0 - Fx forces are not included in the plot, load or field creation
(default)
- 1 - Fx forces are included in the plot, load or field creation
- fxy=<value>
- 0 - Fxy resultant forces are not included in the plot (default)
- 1 - Fxy resultant forces are included in the plot
- fxyz=<value>
- 0 - Fxyz resultant forces are not included in the plot (default)
- 1 - Fxyz resultant forces are included in the plot
- fxz=<value>
- 0 - Fxz resultant forces are not included in the plot (default)
- 1 - Fxz resultant forces are included in the plot
- fy=<value>
- 0 - Fy forces are not included in the plot, load or field creation
(default)
- 1 - Fy forces are included in the plot, load or field creation
- fyz=<value>
- 0 - Fyz resultant forces are not included in the plot (default)
- 1 - Fyz resultant forces are included in the plot
- fz=<value>
- 0 - Fz forces are not included in the plot, load or field creation
(default)
- 1 - Fz forces are included in the plot, load or field creation
- gpf=<value>
- 0 - Grid-point forces do not participate in the FBD calculation (default)
- 1 - Grid-point forces do participate in the FBD calculation
- intf=<value>
- 0 - Internal forces do not participate in the FBD calculation (default)
- 1 - Internal forces do participate in the FBD calculation
- mpcf=<value>
- 0 - MPC forces do not participate in the FBD calculation (default)
- 1 - MPC forces do participate in the FBD calculation
- mx=<value>
- 0 - Mx moments are not included in the plot, load or field creation
(default)
- 1 - Mx moments are included in the plot, load or field creation
- mxy=<value>
- 0 - Mxy resultant moments are not included in the plot (default)
- 1 - Mxy resultant moments are included in the plot
- mxyz=<value>
- 0 - Mxyz resultant moments are not included in the plot (default)
- 1 - Mxyz resultant moments are included in the plot
- mxz=<value>
- 0 - Mxz resultant moments are not included in the plot (default)
- 1 - Mxz resultant moments are included in the plot
- my=<value>
- 0 - My moments are not included in the plot, load or field creation
(default)
- 1 - My moments are included in the plot, load or field creation
- myz=<value>
- 0 - Myz resultant moments are not included in the plot (default)
- 1 - Myz resultant moments are included in the plot
- mz=<value>
- 0 - Mz moments are not included in the plot, load or field creation
(default)
- 1 - Mz moments are included in the plot, load or field creation
- resfileid=<value>
- The result file ID for resultid. Useful when multiple result
files are loaded for a single result entity.
- resolvein_sys=<value>
- 0 - Resolve in analysis system (default)
- 1 - Resolve in global system
- 2 - Resolve in user system
- resultant=<value>
- 0 - Free body force/moment plot
- 1 - Resultant force/moment plot
- resultid=<value>
- The result entity ID.
- scid=<value>
- The results subcase ID for resultid.
- scientific=<value>
- 0 - Fixed format text (default)
- 1 - Scientific format text
- showvalue=<value>
- 0 - Show text (default)
- 1 - Hide text
- sizescale=<value>
- 0 - Constant FBD plot arrow length (default)
- 1 - Magnitude FBD plot arrow length
- spcf=<value>
- 0 - SPC forces do not participate in the FBD calculation (default)
- 1 - SPC forces do participate in the FBD calculation
- stepid=<value>
- The step/simulation ID for scid.
- tolerance=<value>
- The tolerance to limit the values. Default is 0.00001.
- user_sys_id=<value>
- The system ID when resolvein_sys=2.
- vecstyle=<value>
- 0 - 3D FBD plot arrow (default)
- 1 - 2D FBD plot arrow
- num_strings
- Integer indicating the size (number of strings) in the data_strings
array.
Create an FBD force
plot:
*createstringarray 48 "scientific=1" "resultant=1" "arroworigin=0" "tolerance=0.00001"
"scid=1" "resfileid=1" "resultid=1" "showvalue=1" "stepid=1" "sizescale=0" "vecstyle=0" "fx=1" "fy=1" "fz=1" "mx=1" "my=1" "mz=1" "fxy=1" "fyz=1" "fxz=1" "mxy=1" "myz=1" "mxz=1" "fxyz=1" "mxyz=1" "gpf=1" "appf=1" "spcf=1" "intf=1" "mpcf=1" "arrlen=75" "declim=2" "freenode=2" "display=1" "colorfx=3" "colorfy=4" "colorfz=5" "colorfxy=7" "colorfyz=8" "colorfxz=9" "colorfxyz=12" "colormx=3" "colormy=4" "colormz=5" "colormxy=7" "colormyz=8" "colormxz=9" "colormxyz=12"
set fbdIds {1 2 3}
*fbdforce $fbdIds 1 48
Create
loads:
*createstringarray 21 "createload=1" "resolvein_sys=3 " "user_sys_id=2" "scid=1" "resfileid=1" "resulted=1" "stepid=1" "fx=1" "fy=1" "fz=1" "mx=1" "my=1" "mz=1" "tolerance=0.00001" "gpf=1" "appf=1" "spcf=1" "intf=1" "mpcf=1" "display=0" "freenode=1"
set fbdIds {1 2 3}
*fbdforce $fbdIds 1 21
Create a
field:
*createstringarray 21 "createfield=1" "resolvein_sys=3 " "user_sys_id=2" "scid=1" "resfileid=1" "resulted=1" "stepid=1" "fx=1" "fy=1" "fz=1" "mx=1" "my=1" "mz=1" "tolerance=0.00001" "gpf=1" "appf=1" "spcf=1" "intf=1" "mpcf=1" "display=0" "freenode=1"
set fbdIds {1 2 3}
Incorrect usage results in a
Tcl error. To detect
errors, you can use the
catch
command:
# Handle error
